Mac magic mouse orbit function Help
berkeley9DHFL
Message 1 of 14
berkeley9DHFL
Hi im a newbie to 360 fusion ..and have a Mac laptop pro 2015. with a magic mouse2 i believe and i cant get the orbit function to work with it unless i click on the orbit symbol at the bottom of the screen. I tried going to preferences and changing the setting to solidworks or the other thing but every time i tried to use the f2 key it just changes the brightness. then when i check the preference its gone back to Fusion 360. Bit stuck any help would be grateful. Namaste.
Replies (13)
Message 2 of 14
masa.minohara
Hi @berkeley9DHFL,
Thank you for posting in the forum! Just to check, you have changed "Pan, Zoom, Orbit shortcuts" option to SolidWorks in the Preferences menu, but it switches back to Fusion when you hit F2 key, is that correct?
Did you hit Apply or OK button before closing the Preferences menu?
I'm having difficulty reproducing the issue, would you be able to record a screencast of the issue?
Also, I haven't had a chance to try this myself but another user shared a workaround in this forum thread and that may be helpful for you.
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 14
berkeley9DHFL
Hi, no i couldnt see the apply or ok button.. i have applied it now ! however it still doesnt work . it just adjusts the brightness of the screen. Its a laptop so maybe it will not work ? i go to preferences change orbit gestures to Solidworks accept it , it does stay there when i check after closing the window. then press F2 and click still no orbit function.
Message 4 of 14
TrippyLighting
For CAD work my recommendation would be to replace the Magic Mouse with a traditional 2-button and scroll-wheel mouse. I've tried to work with the magic mouse for over a year with a different 3D software (before Fusion 360 was out) and it was slow, imprecise and generally unpleasant.
Message 5 of 14
berkeley9DHFL
Thanks for that I was begining to suspect that would be the case ! Can i just use a Generic one ? and will it work with the Apple mac laptop ?
Message 6 of 14
TrippyLighting
I use a Razer Orochi (cabled) on my mid 2010 27" iMac and now use a Razer Atheris (wirelss,  not Bluetooth) without problems with my 2017 15" MacBook Pro.
I have relatively large hands, but like small mice, thus the use of small mobile gaming mice. You should be able you use any nomal 2-button scroll-click-wheel mouse.
Message 7 of 14
cor-loss
Hi there!
First of all: WHY IS THIS A PROBLEM??? GET YOUR S**T TOGETHER AUTODESK!!! A basic funtion like this should work from the beginning on a Mac with an Apple mouse.
Even though this thread is nearly a year old I want to share my solutions.
I had the same problem and didn't want do buy a new mouse.
SOLUTION 1 (Simple and free): change the "Pan, Zoom, Orbit shortcuts" in the preferences to SolidWorks. Then go to Mac Systempreferences and select the option to use the "F-buttons" with standard funktions. otherwise you have to press fn+F2.
But because I didn't want to press F2+mous button I went for...
SOLUTION 2 (best!): Get BetterTouchTool. There is a free trial and the full version is around 6$ and worth it. With this tool you can create gestures for mouse and trackpad with custom funktions. I created a 3-finger klick with the funktion "middle click". And boom... I'm able to orbit and pan with my simulated middle click.
Message 8 of 14
bratin.mukherjee1
Thanks for the advice. It works but the response is too slow, in fact the rotation is not free. Any solution for that?
Message 9 of 14
SEIZMICdesign
Ladies & Gentlemen.
There is a VERY simple solution to this that I have been using with much success for several years now.
Download Either MagicPrefs (what I use - it's free, but will eventually stop working) or Better Touch Tool (what I will have to switch to when Magic Prefs no longer works).
Either will work great. Problem solved.
EDIT: I didn't completely read @cor-loss's post completely - beat me to it. Advice stands.
Message 10 of 14
I was looking for this also and noticing that this thread is over 3 years old and no solution irked me to no end.  however I finally found something that works with the magic mouse.  Bear with me since I am just learning to use fusion 360 and don't know how this solution will be better or worse but at least I found the orbiter on the mouse.      I went into my preferences in fusion 360 and scrolled down to choose  TINKERCAD in pan, zoom, orbiter .   then selected APPLY,  and then OK.   NOW I get orbiter control by top clicking and holding the magic mouse while orbiting around.   It feels like my middle finger is almost falling off the edge of the magic mouse when doing it but hey it works.   its basically press down the 2 O'Clock edge of the mouse for orbiter ....good luck amigos.
Lando
Message 11 of 14
daniel_lyall
I binned mine it is so much better if you get a big 5 button mouse.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 12 of 14
wokky7JTFT
You are basically describing Right Click on magic mouse. Yes correct thats what I use without any third party applications. Right click and hold for orbiter and right click for context menu and choose Pan. When you get used to it all work fast and naturally.
Message 13 of 14
dvdmueller
Observer
Observer
@@xlando wrote:
... NOW I get orbiter control by top clicking and holding the magic mouse while orbiting around.   It feels like my middle finger is almost falling off the edge of the magic mouse
This is a good solution. If you don't want to right-click with your middle finger off the edge, you can hold the Control key and then click the mouse anywhere.
Message 14 of 14
suguDFAJA
Community Visitor
Community Visitor
bless!!!! this worked
