Mac Installation Support - Permission Denied
knock
Message 1 of 26
knock
Been trying every option..  no avail. I cannot install this on my personal MacBook Pro.. Current version.
Im attempting to install a personal version of Fusion.
Replies (25)
Message 2 of 26
RajkumarIlanchelian
@knock Please check this article for help on this install problem - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Fusion-360-Install...
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 26
knock
I went through all of the setting and permissions..   so I created a new user and that seemed to work for install..   I just don't know what I'm missing in my Main User account that is denying access....       When I did create a new user.. a little popup appeared to ALLOW...  I cannot seem to get that anymore
Message 4 of 26
knock
I do not understand how my MAIN User account, which has full admin rights, cannot have Fusion installed!!!!  It works if you create a new Admin User.. BUT not on my main account.  It is so frustrating.. I am going to abandon Autodesk and Fusion and seek a new CAD!
Message 5 of 26
RajkumarIlanchelian
@knock you can check in your macOS setting for allowing access to Fusion that may be causing Fusion to not install. We can help to look into what could be happening with this particular account but if you have already moved on, we completely understand. Apologies for the experience you have been having with Fusion.
Autodesk Fusion
Join Fusion Insider
Message 6 of 26
knock
Sure. How do I do that?
Message 7 of 26
RajkumarIlanchelian
@knock before we start with anything else can you please try the below?
1.Go to launchpad- Uninstall Autodesk Fusion
1 Go to /Users/user/Library/Application Support (Finder - Go - go to folder - /Users/your user name/Library/Application Support/)
2 Delete the Autodesk folder
3. Delete the shortcut that you use to launch Fusion
4. Restart your machine
5. Now install Fusion again.
Autodesk Fusion
Join Fusion Insider
Message 8 of 26
knock
Done...  Autodesk is nowhere to be found on my Mac.  I restarted machine.  Tried to Install.. Still get Errno 13 message.  Installer goes all the way to 99% and I get that error message.
Message 9 of 26
RajkumarIlanchelian
@knock "Autodesk is nowhere to be found on my Mac" - IF you go to finder and find folder  ~/library/Application options folder you are not seeing Autodesk folder? Can you screen grab what folders you see in this location?
Autodesk Fusion
Join Fusion Insider
Message 10 of 26
knock
Screenshot attached for ~/library/application support
Message 11 of 26
RajkumarIlanchelian
@knock This is not the location we want but the user level application support. So let's try this a different way.
1 GO - Go to folder
2. Type /users/- it should show you your user name
3. /Users/user name/ type library /Application support
Now you should see the Autodesk folder.
Autodesk Fusion
Join Fusion Insider
Message 12 of 26
knock
So I found the AutoDesk folder and deleted it... I did a shutdown and restart and attempted to re-install.  This time it was different and took longer than prior attempts.  A pop-up appeared that said it was Verifying Fusion.  All looked well until it hit 99% and I got the Errno 13 message...   attached is my log
Message 13 of 26
knock
SOLVED!!!!
I found that /users/username/Applications folder only had "System" as READ/WRITE...   I had to add my username to the folder and give full permissions..  all good and installed..
Thanks for the outstanding support... I was sooooo close to moving onto another product...
Message 14 of 26
RajkumarIlanchelian
@knock @Excellent. Glad this is resolved now. Please let us know if you have any other issues.
Autodesk Fusion
Join Fusion Insider
Message 15 of 26
slaaavyn
Observer
Observer
In my case, the solution to the installation problem is to grant 'Application Management' permission to the 'Install Autodesk Fusion' program.
1. Open 'System settings'
2. Select 'Privacy & Security' from main menu list
3. Select 'App Management' from list in 'Privacy & Security'
4. Turn the switch to the on position against the 'Install Autodesk Fusion' application
5. Start the installation
I hope this solution will help all future users.
Message 16 of 26
benrmjones
Community Visitor
Community Visitor
thank you so much you haver just saved me so much
Message 17 of 26
d_orman1
Community Visitor
Community Visitor
Hello!
I have nothing in this folder. Could you please help me
Message 18 of 26
RajkumarIlanchelian
@d_orman1 Are you hitting the same issue? Also what is your location of install as in the country you are from trying to install Fusion?
Autodesk Fusion
Join Fusion Insider
Message 19 of 26
jason_iveyMUY9T
Community Visitor
Community Visitor
I'm having the exact issue- I can successfully install Fusion when I set up another user on my Mac but not on my main account.  I have been through all suggestions on this board and nothing seems to work.  I have deleted the Autodesk folder, given it all the various permissions I can give it and it still comes back with the error "Access to install directories failed".  This seems like a bug on the Autodesk side, as I have never had this issue with any other software- and I have been trying to do an install on this machine periodically over the past couple of years, thinking Autodesk would get enough complaints and finally look into and fix this issue.
BTW, it is the education version I am trying to install.
Any help would be greatly appreciated as this is extremely frustrating.
TIA
Message 20 of 26
RajkumarIlanchelian
@jason_iveyMUY9T To confirm you have not been able to install Fusion on your main account for the past 2 years? You canned it out that you can install it on the same machine as a different user and hence we will have to figure out what settings inter current user is blocking Fusion.
1. When you say you are installing the education version, are you downloading the installer from a special education location?
2. When the install fails, does it give you logs that you can attach here?
Autodesk Fusion
Join Fusion Insider
