Lost weeks of work - Fusion
ian_mitchell57
Observer Observer
ian_mitchell57
Observer
Observer
I am using Fusion 360 on the free subscription for non commercial use.
I have been working on quite a complex model, I saved and closed it last night, when i came to open it again today the version it is bring up is about 3 weeks old. I cannot seem to find the latest version at all.
@ian_mitchell57 - Your post title was modified to add the product name and version and moved to Fusion Support forum to increase findability by @CGBenner  - Original: Lost weeks of work
RajkumarIlanchelian
@ian_mitchell57 Can you please try a couple of things for me please?
1. IF you out Fusion in offline (remove Internet) and then launch are you able to open the file that you saved last night?
2. In your data panel versions how many versions are there? Is any of the older versions what you saved yesterday?
Can you also collect log files for us? Once you collect the logs, let us know that name of the file you are using.
Windows:
  1. Go to add/remove programs- select Fusion - MODIFY
  2. This will launch the service utility
  3. gather system info
  4. Attach the Fuiondiagnosticslogs.zip
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
ian_mitchell57
Observer
Observer
Hi Thanks for the help.
I tried it without internet and it was the same problem.
I can only see one version of the model, the out of date version, it is called 'Layout'
I have extracted the file you asked for, hope it helps.
ian_mitchell57
Observer
Observer
OH....
For some reason I simply can't explain the model has returned to how it was when i last used it!
I have no idea what i did, other than turning the internet of and on and launching the service utility???
RajkumarIlanchelian
@ian_mitchell57 Glad you got back the file. Hard to explain what could have happened here but likely a network issue of some sort that could not have synced the file correctly is my best guess.
Autodesk Fusion
Join Fusion Insider
heather_tracy
Hello, @ian_mitchell57,
Did the information provided by @RajkumarIlanchelian help you and answer your question?
If yes, please click on the "Accept Solution" button. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Heather | Community Manager
