Lost bodies in browser for a component
jonasb-n
jonasb-n
I think there is a bug in the latest update. When I select a body in my design window it changes to blue and the associated bodies entry is underlined in the browser, but when I click the bodies line to expand it, no bodies show up. This can be seen in the screen capture jpg included. Only one component was affected. It was fine the last time I opened the component to look at the bodies, and I have not changed this component since then.
g-andresen
you can see the body in the timeline?
günther
jhackney1972
Could you attach your model so others can take a look at this condition?  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
davebYYPCU
Click on down arrow for bodies folder - as it is collapsed in that picture.
Might help....
jonasb-n
The bodies folder is open in the drawer component. Not sure about the timeline since further changes caused the problem to resolve itself. I had to rebuild some of drawer bodies and delete some of them. This resulted in the bodies moving from the drawer component to the main design bodies folder. I moved them back to the drawer component and they appear correctly. Clearly some software link got corrupted, but rebuilding things sorted it all out. Everything works OK now.
