Look At (in sketch Front View) flips orientation
boelZCKBD
boelZCKBD
Hey,
When I make a sketch, and I use the "Look At" option, F360 flips my orientation. So Front view, Z is up, I draw some lines and when I want to have an overview, I use the Look At button. But that cause my Front view to flip (with Z going down thus). It even shows the shadow on the orientation cube on the top side.
What confusses me the most is that this only happens in the Front view. All other react as should be...
(view in My Videos)
Did I changed some unknown setting?
sutherland-
Hi @boelZCKBD
Have you tried to change the up axis from Z to Y?
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
boelZCKBD
Yes, I tried it but the same thing happens.
It has been fine for 3 years, but as a week ago, this misorientation happend.
jhackney1972
This is a know issue and hopefully will be fixed in a future update.
John Hackney, Retired
