Logitech MX Master 3S: Unable to map forward/back buttons with Fusion
FrodoLoggins
Advisor Advisor
FrodoLoggins
I want to hit the forward button on my mouse to redo actions in Fusion and hit the back button on my mouse to undo actions in Fusion.Screenshot 2024-10-22 at 8.40.21 AM.png
I've tried mapping the buttons as redo/undo [as shown in image above] as well as mapping them as forward/back. However hitting them doesn't redo/undo actions in Fusion.
I know Logitech Options+ identifies Fusion correctly as I can disable the Thumb wheel. Previosly rotating the thumb wheel would make Fusion's camera pan left/right. But I just disabled that [as shown in image above] and it has no effect as expected.
No issues panning/orbiting Fusion's camera by holding down center scrollwheel
Logi Options+ is up to date
Mouse firmwware up to date
MacOS up to date
Fusion just updated this morning to 2.0.20494
Restarted Mac multiple times
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
philippmk
Have you added Fusion to LogiOptions+ by using ADD OTHER APPLICATION and setting the following path?
/Users/%username%/Library/Application Support/Autodesk/webdeploy/production/Autodesk Fusion 360.app
This is how I configured Fusion in LogiOptions+. I also tested mapping the forward/back buttons to redo/undo on my MX Ergo, and it did work in Fusion.
niikpalmer
Mine was in a slightly diff place. but eventually I found it and it worked. Could be because I am in the beta?
/Users/%username%/Library/Application Support/Autodesk/webdeploy/production/%randomhashnumber%/Autodesk Fusion.app
