Loft tangency issues
markzonf360
Message 1 of 11
markzonf360
Hi, it seems this is an old issue, but I am hopeful someone has a workaround for what is a most basic issue. Can anyone assist with getting tangency through all of these control points? I have been experimenting for hours upon hours, but to no avail.
Replies (10)
Message 2 of 11
g-andresen
Please share the file for reply.
File > export > save as f3d on local drive  > attach to post
günther
Message 3 of 11
markzonf360
Thanks for looking at this!
Message 4 of 11
g-andresen
The lower body are heavily fragmented.
The cause cannot be determined as sketches are missing.
Are these sketches available in a different version or are there dimensions that can be used to restore the profiles?
Günther
Message 5 of 11
markzonf360
There are no sketches missing. The 'lower body' (is that the surfaced part?) is a set of surfaces extracted from a provided model. There should only be one sketch for the circle. Thanks.
Message 6 of 11
g-andresen
@markzonf360  schrieb:
 … is a set of surfaces extracted from a provided model.
That is exactly the cause!
Günther
Message 7 of 11
markzonf360
F360 cannot handle imported surfaces? It was a step file. It's pretty basic?
But if you think this is the problem, I will replicate the surfaces with two sketches and see if the same problem occurs.
Thanks.
Message 8 of 11
g-andresen
That works very well.
However, the imported body was not created “cleanly” and resembles a patchwork
günther
Message 9 of 11
markzonf360
Hi, I updated the model with a new surface using only sketches. The rails are better but the result still has some surface irregularities? Thanks.
Message 10 of 11
g-andresen
In this case, it is better to create the fillets in the sketches.
(view in My Videos)
günther
Message 11 of 11
markzonf360
OK, thanks for your help!
