loft command
loft command
Artgoodw
loft command
Artgoodw
Hi
I have been trying to create this "shampoo bottle" sketch using the spline and loft command following a tutorial.
I have tried numerous times but when I go to select the rails I get the folowing error message (see screen shot) but I should get (according to tut) (see SS2)
Any help would be greatly appreciated.
Art
jhackney1972
Please attach your model.  It is hard to tell what the issue is from pictures.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
jhackney1972
Please see this Forum post for the solution to this question.
