Lines don't snap to place
Hello, When I am sketching on a hex nut I can't get the line points to snap into the corners, and because of that I cant revolve the shape later on.
This link is to the video i folowed, the problem occurs at 2:24.
HughesTooling
I expect the problem is in the video he has auto project enabled and you don't. You just need to press P and manually project the point you need. Auto project was turned off a while ago as it tends to project a lot of stuff you don't need and clutters up sketches.
Mark
Mark Hughes
Owner, Hughes Tooling
Thank you so much for your good and quick answer to my question. It was very helpful, now I have made a hex nut. You totally made my day because I have been struggling whit this problem for weeks. Thank you once again!!!
