Line size problem
Line size problem
Line size problem
Hello everybody,
when I draw a line the command asks me to specify the starting point and the length; I enter the value and confirm but I get a line of a different size than the one requested.
how can i solve?
Thank you
g-andresen
please show this behaviour in a screencast and share the file
File > export > save as f3d locally  > attach it to the next post.
günther
TheCADWhisperer
@Anonymous wrote:
...but I get a line of a different size than the one requested.
how can i solve?
Is a dimension placed?
If yes, double click on the dimension and edit to desired value.
If no, the place a dimension of desired value.
jhackney1972
It sounds like your computer operating system is Windows 7.  Windows 7 does not support Fusion 360 completely and this is one of the symptoms.  You can search the web for possible workarounds including using the dimension command AFTER placing the line.
John Hackney, Retired
