Lift Design Help
Lift Design Help
bar20001566
Observer Observer
Lift Design Help
bar20001566
Observer
Observer
Hi, having some problems with a lift design. It involves the rotation of two powerscrews through a gear system, which should convert rotational movement to the lateral (up/down) movement of the lift. However, the motion link between the slider joint of the lift and revolute joint of the gears causes the lift to spin around. I have attached some pictures if it helps. I am quite new to fusion, so my mistake may be obvious. Any help would be much appreciated:)
g-andresen
double post
günther
