Lathe linking problem
jerrybentley
jerrybentley
I'm having a problem with a id job on the lathe side.    Its in the linking tab on the x clearance.   I am posting a screen shot.  I don't understand this problem enough to explain anymore.  I just know it does not make a difference what value I put in the x box it doesn't fix the error.   Where am I going off the rails ?.
JB
HughesTooling
If you hover the mouse pointer over the error you will get an explanation of the problem. The X clearance need to be less than the depth of cut, you can ignore the warning but you'll get air cutting.
Mark
PS
Please don't attach pictures. There's an option Photos on the editor toolbar to embed them, please use this option.
Mark Hughes
Owner, Hughes Tooling
jerrybentley
Thanks again Mark.
