Latest update broke my keyboard shortcuts!?!?!!?!!?
Zammer8
Zammer8
I have ` bound to Create Sketch and Finish Sketch. This has worked fine for me for years now. But in this latest update, ` no longer finishes the sketch. It says there's a conflict. Figured you added some new keyboard shortcut that overrode mine, but no, it's conflicting with Create Sketch. Turns out I'm not allowed to have Create and Finish both mapped to the same key? Why? It's fairly obvious which one to use. If I'm in the Sketch interface, finish it. If I'm not, create a sketch. Pretty simple. So why did you break it? How do I get around this, or how do I downgrade?
justhenderson11
I have an issue now, every time I ctr+C/V a notification comes up saying i have overlapping keyboard shortcuts. It still works but the notification is annoying. If there is a setting outside of the toolbar to change these I can't find it..
moritzLCGFK
seems like there is an bug so shortcuts are not longer separated depending on when/ where you are using it?!
Pressing "e" inside a sketch does not longer acitvate the constrain "equal", but also starts an extrusion 😕
infoZFTNZ
Observer
Observer
I'm having the same issue, anyone found a solution?
CarlConquilla
No and there seems to be no official comment from the Autodesk team either. This is a reminder every day that we should keep an eye out for better, more trustworthy software.
