Laser on during initial move
myjunkmail2209
Message 1 of 8
myjunkmail2209
I decided to try Fusion for some laser etching/cutting, and I've noticed something odd and annoying.
The laser is on for the initial move from the WCS origin to the starting location.
Is this an issue with Fusion, my post-processor or user error?
Output from post-processor:
;HyperCube CAM post processor for Fusion360: Version 1.0
;Compatible with Marlin 1.1.4+
;By Tech2C
;https://www.thingiverse.com/thing:1752766
;https://www.youtube.com/watch?v=n2jM6v3E7sU...
M117 Starting...
M5 ;Laser/Fan OFF
G21 ;Metric Values
G17 ;Plane XY
G90 ;Absolute Positioning
G92 X0 Y0 Z0 ;Set XYZ Positions
G0 F2500
G0 Z0 F300 ;Position Z
M400
M117 Outside
M3 S192
G1 X-9 Y-211.36 Z0
G1 X-8
G1 Y0
G1 X8
G1 Y-211.36
G1 X-8
G1 X-9
M400
M5 ;Laser/Fan OFF
G0 F2500
M84 ;Motors OFF
M117 Finished​
Replies (7)
Message 2 of 8
myjunkmail2209
I think it is the post processor that is causing the issue.
Could someone please look over the following to see if the problem is evident.
  By Tech2C
  https://www.youtube.com/watch?v=n2jM6v3E7sU&list=PLIaArjwViQRVAERWRrYfe9rtiwvvRGCzw
  Changed to M3 Sxxx - Laser on @ power Sxxx
  Changed to M5 - Laser OFF
  Adapted from 'Generic Grbl' (grbl.cps) and 'Dumper' (dump.cps)
description = "HyperCube for Fusion360";
vendor = "Marlin";
vendorUrl = "https://github.com/MarlinFirmware/Marlin";
extension = "nc";
setCodePage("ascii");
capabilities = CAPABILITY_INTERMEDIATE;
tolerance = spatial(0.002, MM);
minimumChordLength = spatial(0.01, MM);
minimumCircularRadius = spatial(0.01, MM);
maximumCircularRadius = spatial(1000, MM);
minimumCircularSweep = toRad(0.01);
maximumCircularSweep = toRad(180);
allowHelicalMoves = true;
allowedCircularPlanes = undefined; // allow any circular motion
// user-defined properties
properties = {
  startHomeX: false,
  startHomeY: false,
  startHomeZ: false,
  startPositionZ: "2",
  finishHomeX: false,
  finishPositionY: "",
  finishPositionZ: "",
  finishBeep: false,
  rapidTravelXY: 2500,
  rapidTravelZ: 300,
  laserEtch: "M3 S128",
  laserVaperize: "M3 S255",
  laserThrough: "M3 S192",
  laserOFF: "M5"
var xyzFormat = createFormat({decimals:3});
var feedFormat = createFormat({decimals:0});
var xOutput = createVariable({prefix:"X"}, xyzFormat);
var yOutput = createVariable({prefix:"Y"}, xyzFormat);
var zOutput = createVariable({prefix:"Z"}, xyzFormat);
var feedOutput = createVariable({prefix:"F"}, feedFormat);
var planeOutput = createVariable({prefix:"G"}, feedFormat);
// circular output
var	iOutput	= createReferenceVariable({prefix:"I"}, xyzFormat);
var	jOutput	= createReferenceVariable({prefix:"J"}, xyzFormat);
var	kOutput	= createReferenceVariable({prefix:"K"}, xyzFormat);
var cuttingMode;
function formatComment(text) {
  return String(text).replace(/[\(\)]/g, "");
function writeComment(text) {
  writeWords(formatComment(text));
function onOpen() {
  writeln(";***********************************************************************************");
  writeln(";HyperCube CAM post processor for Fusion360: Version 1.0");
  writeln(";Compatible with Marlin 1.1.4+");
  writeln(";By Tech2C");
  writeln(";https://www.thingiverse.com/thing:1752766");
  writeln(";https://www.youtube.com/watch?v=n2jM6v3E7sU&list=PLIaArjwViQRVAERWRrYfe9rtiwvvRGCzw");
/** Force output of X, Y, and Z. */
function forceXYZ() {
  xOutput.reset();
  yOutput.reset();
  zOutput.reset();
/** Force output of X, Y, Z, and F on next output. */
function forceAny() {
  forceXYZ();
  feedOutput.reset();
function onSection() {
  if(isFirstSection()) {
    writeln("");
	  writeWords("M117 Starting...");
	  writeWords(properties.laserOFF, "         ;Laser/Fan OFF");
    writeWords("G21", "          ;Metric Values");
	  writeWords(planeOutput.format(17), "          ;Plane XY");
	  writeWords("G90", "          ;Absolute Positioning");
	  writeWords("G92 X0 Y0 Z0", " ;Set XYZ Positions");
	  writeWords("G0", feedOutput.format(properties.rapidTravelXY));
	  if(properties.startHomeX) { writeWords("G28 X", "        ;Home X"); }
	  if(properties.startHomeY) { writeWords("G28 Y", "        ;Home Y"); }
	  if(properties.startHomeZ) { writeWords("G28 Z", feedOutput.format(properties.rapidTravelZ), "    ;Home Z"); }
	  if(properties.startPositionZ) { writeWords("G0 Z" + properties.startPositionZ, feedOutput.format(properties.rapidTravelZ), "   ;Position Z"); }
  if (currentSection.getType() == TYPE_JET) {
    if(currentSection.jetMode == 0) {cuttingMode = properties.laserThrough }
	else if(currentSection.jetMode == 1) {cuttingMode = properties.laserEtch }
	  else if(currentSection.jetMode == 2) {cuttingMode = properties.laserVaperize }
	    else {cuttingMode = (properties.laserOFF + "         ;Unknown Laser Cutting Mode") }
  if (hasParameter("operation-comment")) {
    var comment = getParameter("operation-comment");
    if (comment) {
	    writeln("");
	    writeWords("M400");
      writeComment("M117 " + comment);
function onDwell(seconds) {
  if (seconds > 99999.999) {
    warning(localize("Dwelling time is out of range."));
  seconds = clamp(0.001, seconds, 99999.999);
  writeWords("G4 S" + seconds, "        ;Dwell time");
function onPower(power) {
  if (power) { writeWords(cuttingMode) }
  else { writeWords(properties.laserOFF) }
function onRapid(_x, _y, _z) {
  var x = xOutput.format(_x);
  var y = yOutput.format(_y);
  var z = zOutput.format(_z);
  if (x || y) {
    writeWords("G0", x, y, feedOutput.format(properties.rapidTravelXY));
  if (z) {
    writeWords("G0", z, feedOutput.format(properties.rapidTravelZ));
function onLinear(_x, _y, _z, _feed) {
  var f = feedOutput.format(_feed);
  if(x || y || z) {
    writeWords("G1", x, y, z, f);
  else if (f) {
    writeWords("G1", f);
function onCircular(clockwise, cx, cy, cz, x, y, z, feed) {
  // one of X/Y and I/J are required and likewise
  var start = getCurrentPosition();
  switch (getCircularPlane()) {
  case PLANE_XY:
    writeWords(planeOutput.format(17), (clockwise ? "G2":"G3"), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), feedOutput.format(feed));
    break;
  case PLANE_ZX:
    writeWords(planeOutput.format(18), (clockwise ? "G2":"G3"), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), feedOutput.format(feed));
    break;
  case PLANE_YZ:
    writeWords(planeOutput.format(19), (clockwise ? "G2":"G3"), xOutput.format(x), yOutput.format(y), zOutput.format(z), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), feedOutput.format(feed));
	break;
  default:
    linearize(tolerance);
function onSectionEnd() {
  writeWords(planeOutput.format(17));
  forceAny();
function onClose() {
  writeln("");
  writeWords("M400");
  if(properties.finishPositionZ) { writeWords("G0 Z" + properties.finishPositionZ, feedOutput.format(properties.rapidTravelZ), "   ;Position Z"); }
  if(properties.finishHomeX) { writeWords("G28 X", "        ;Home X"); }
  if(properties.finishPositionY) { writeWords("G0 Y" + properties.finishPositionY, "      ;Position Y"); }
  writeWords("M84", "          ;Motors OFF");
  if(properties.finishBeep) { writeWords("M300 S800 P300"); }
  writeWords("M117 Finished :)");
Message 3 of 8
carl.j.barker
Just looking at the code, I'd say that this line
G1 X-9 Y-211.36 Z0
Should be a G0. or otherwise be done before the laser is turned on.
Can you show fusions output for this - right click the toolpath in the browser and choose 'view toolpath'
so we can see what fusion is sending to the PP.
Message 4 of 8
myjunkmail2209
Message 5 of 8
carl.j.barker
Well the post is outputting correctly as far as I can tell.
Your tool path is missing the initial rapids to start point (or what ever the personal version outputs, Guessing just a linear ).
Can you share the design with the setup and toolpathing on it?
Message 6 of 8
myjunkmail2209
Message 7 of 8
myjunkmail2209
I've also noticed that when I stack duplicate operations, the laser is not turned off at the end, before moving back to the initial starting position to go around again - Just ruined a nice bit of leather 😞
Message 8 of 8
myjunkmail2209
Thanks for your assistance Carl.
I've discovered that the power on at the start seems to be an aberration as I cannot replicate the fault in a new design.
The power remaining on between sections was a flaw in the post processor that I'm using.
