keyboard shortcuts export and import
badonj002
Message 1 of 11
badonj002
A little confused here. I see I can make keyboard shortcuts to customize for my use, but nowhere in settings is there a way to export settings so I can import them in the event I have to reinstall  my computer. I see in 2017 the shortcuts are shown as we are working on it, but I do not see it in preferences like in this post? Is this sort of thing not not normal in applications such as Fusion 360?
https://forums.autodesk.com/t5/fusion-360-design-validate/under-development-customizable-keyboard-sh...
I did not expect this to be the case. 200+ functions, it can not be expected I have to enter all of then every time I have to reinstall Fusion?
Replies (10)
Message 2 of 11
g-andresen
maybe this might help?
günther
Message 3 of 11
badonj002
Thank you! I have been looking everywhere for the answer. I think I will be working on a shortcut Editor. Seriously, thank you for taking the time to help me!
Message 4 of 11
Phil.E
Hi. Your keyboard shortcuts are stored in the cloud. There is a current issue that requires a small workaround when you do something like install or login. Basically any time you have to log in.
What happens is Fusion is already started before you log in. It doesn't know your shortcuts yet, because it started without knowing who you are. This would also happen when you install because it forces a login.
Here is the way to get them back right away. Right after installing or logging in, restart Fusion 360 and do not log out. Just restart. Fusion will know who you are at this point and fetch your shortcuts from the cloud.
Thanks for your patience with this issue.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 11
What do you mean restart? just exit the program and relaunch it? I tired this couple times but not working
Message 6 of 11
Phil.E
Can you describe what is not working?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 7 of 11
This bug did not bother me when I was using Fusion with the hobiest license, but now since I`m paying **** ton of money for a license I expect this be fixed at this point.
Message 8 of 11
Phil.E
Can you describe what is not working for you?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 9 of 11
ghrrum
This has been bugging the heck out of me for ages and I finally cracked it.
I'm going to run through the play by play using text and images cause video is too slow to explain for most things.
  1. Start Fusion 360 and log into the account you want to export your hotkeys from.
  3. I prefer to expand the window to read everything, you do you. At the very bottom click the 'Type Text Commands Here' and type "HotKey-Export" without quotes and hit enter.HotKey-Export.jpg
  4. Log Out of that profile and into the one you want to import the shortcuts into. Text Command window should carry over unless you close it.
  5. Once logged in type "HotKey-Import" into the text command line and, viola, you should be done and have all your hotkeys moved.HotKey-Import.jpg
There are lot of other text commands in there that are VERY useful to know about, I highly suggest exploring it and seeing what sort of stuff you can do there. Be careful though, you can mess up stuff in a big way too.
Message 10 of 11
ghrrum
I suspect there is a way to carry your toolbars over so you can migrate your workspace over to a different account, I'll poke about and explore it a bit more and see if that can be done too.
Message 11 of 11
MarcBanks_Bl
Ever figure this out?
