keep dimensions visible but hide the points and lines
I would like to keep the dimensions visible but hide the sketch points and lines.
jeff_strater
No, there is no way today to keep the dimensions visible without the sketch geometry also being visible.  Can I ask why you want to have that configuration of visibilities?
Jeff
Jeff Strater
Engineering Director
I have to give this to a fabrication shop and i don't want to confuse them. instead i will create a drawing where i am pretty sure i can define dimensions in fractional inches.
should i delete this thread?
jeff_strater
No, no need to delete it.  If it shows up in a search, it might help someone else who has a similar question in the future.
Jeff
Jeff Strater
TimeraAutodesk
Hi @Anonymous have you tried using the Drawings workspace to create the dimensions you need? If you create a drawing with Inch units, you can also get fractional units which sounds like would be helpful for your purposes.
Let us know if you need any additional help.
Timera
