Just curious if this is a glitch or a problem with modeling
Will1337
Will1337
I have run into this issue while learning nurbs modeling in the surface tool work space. I am wondering if maybe this is a bug or something.
Please excuse the unconstrained sketch as I was just trying to create a scenario where this problem shows up for me.
I am trying to learn so if I am doing something wrong please let me know.
Phil.E
Thanks for posting.
I tested your design and found some issues. So it's a glitch. I logged a bug report for it.
If you are using this workflow with your non-test design shapes, and run into the same issue, please post again.
(ref: FUS-121654)
Phil Eichmiller
Software Engineer
Quality Assurance
Will1337
Thanks, yeah I have run into it a few times, once it happens it seems to corrupt other surfaces
TrippyLighting
@Will1337 thanks for reporting this. I've come across it many times and then usually resort to split face or split body with a subsequent delete.
However, to get to a solid body enclosed by these 6 surfaces, you may want to look at the boundary fill tool.
Phil.E
I didn't find any corruption. Thanks for posting. When you have an example of a part you are making with this issue, please post again.
Phil Eichmiller
Software Engineer
Quality Assurance
Will1337
Oh what I meant was once it happens, all other trim selections seem to do the same thing. Not a corrupted file or anything.
I came across this problem while learning how to model using surfaces, this was just a quick sketch/model that seemed to recreate the problem I haven't really had a chance to make anygthing using this process.
