June 11, 2018 Cloud rendering
thom.tremblay
Message 1 of 10
thom.tremblay
I've been running into severe problems cloud rendering with the June 11 update. The model becomes very scrambled displacing components in the view.
This has been on different models on two different Mac OSX systems.
Here's an example:
Thom Tremblay
Author/Instructor
Facebook | Twitter | LinkedIn
Replies (9)
Message 2 of 10
the same here after updating
Message 3 of 10
ryan.bales
Autodesk Support
Autodesk Support
Hi @Anonymous, @Anonymous,
I've logged this issue with the development team this morning. As far as i can tell it only occurs in cloud renders as i've been unable to reproduce rendering locally.
Ryan Bales
Fusion 360 Product Support
Message 4 of 10
Hi Ryan,
Thanks for your reply. Yes, my experience has been the same. Any idea how long it will take for the issue to be resolved?
Best.
Message 5 of 10
ryan.bales
Autodesk Support
Autodesk Support
I do not know off hand.
Ryan Bales
Message 6 of 10
Hi @ryan.bales, @thom.tremblay, @Anonymous It seems that all joints between components are now incorrectly referenced by the cloud rendering process. I have tried and I have got the same error with a simple file, joining 3 cylinders' faces. Do you have the same behavior?
model view, 2 cylinders are already joined togethermodel view, 2 cylinders are already joined togethercloud rendering result error, the 2 cylinders are not joinedcloud rendering result error, the 2 cylinders are not joinedmodel view, after joining the 3rd cylindermodel view, after joining the 3rd cylindercloud rendering result error, the 3rd cylinder disappears form view, after joiningcloud rendering result error, the 3rd cylinder disappears form view, after joining
Message 7 of 10
I have exactly the same problem. Renders are unusable.
Message 8 of 10
ryan.bales
Autodesk Support
Autodesk Support
Hi all!
Please re check cloud rendering. This should be fixed as of 12pm PST. I verified it in my test file and it does appear to be fixed.
Ryan Bales
Message 9 of 10
Thank you @ryan.bales! It seems to be fixed now.
Message 10 of 10
thom.tremblay
I had a chance to check back in on cloud rendering. The model appears in canvas as it does on the right. In the model is a simulation model of a half fluid volume. When the cloud rendering finished, as the image shows, the fluid volume was rendered but not the visible model.
Model rendered on the left based on the model displayed on the right.Model rendered on the left based on the model displayed on the right.
Thom Tremblay
Author/Instructor
