- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to create a fixed joint with a specific alignment between two components. I've created one point on each of the two components, that I would like to be aligned by the joint. However, when I create the joint, instead of the component moving from its original position to its destination, it is the point within the component that moves.
Can someone suggest a solution, or a different workflow to obtain the same result? Thanks!
Screencast of the issue is here: https://autode.sk/3fniKYj
