Joint changes its orientation by 90° right after creating it. Happend on multiple occasions over the years.
spooner777
Message 1 of 8
spooner777
https://youtu.be/GeZHlqnpoYc
I am using Fusion for a few years now and I had this happen in multiple separate files with separate components. All of the files in the Video were created on Fusion360. At first I suspected McMaster screws to be the issue so I got rid of them entirely in my designs. I am using mostly linked components because my designs have several parts that are shared among assemblies. Think about Volkswagen using the same mirror in multiple cars.  This is a bug right? Any idea what causes it?
Replies (7)
Message 2 of 8
g-andresen
please share a sample file
File > export > save as f3d on local device  > attach it to the next post.
günther
Message 3 of 8
spooner777
Here is a sample file. I suspect it could have something to do with unfolding a sheetmetal componnet (foot) and refolding it. Maybe the orientation changes are not recorded properly.
Message 4 of 8
g-andresen
works here
Screencast
That sounds plausible.
Why don't you test it in both variants?
günther
Message 5 of 8
spooner777
Sorry, that was the wrong file. It is when you join the UP part to the hole pattern on the foot part.
Message 6 of 8
jhackney1972
I do not see the issue you describe in this model when placing the components together in either arrangement.
John Hackney, Retired
Message 7 of 8
spooner777
I understand and I can see that, but you can also see the behaviour on my Youtube video right? So something must be broken.
Message 8 of 8
jhackney1972
I can see the issue you are facing but I do not have your model to troubleshoot so I cannot make a judgement either way.  You submitted an assembly that I assume you found exhibited the same behavior as the one you used in the original video.  If you did not, post a model that shows issue you are facing and let others troubleshoot it to determine if they see the error also and either can find out why or classify it as a defect.
