Join sketch lines to existing body
ljrm.manu
ljrm.manu
Community Visitor
Community Visitor
As attached, I have the main body of a pendant I'm attempting to design. I'd like to connect the interior sketch to be one unibody form with the exterior ring. Once connected I would extrude to an equal height and have it CNC machined. Very new to Fusion and never been fantastic with modelling in any software so any and all feedback would be hugely appreciated. Thanks in advance 🙂
g-andresen
If the profile is extrudable (closed contours) call the extrude command.
Then:
1. select profile
2. from object (bottom of the frame) > (only if the profile is not at the same height as the frame)
3. to object > top of the frame
günther
wmhazzard
It looks like your sketch is not closed. Start by looking closely at the white dots in the sketch, those are curves that are not connected. If you sketch a line over the design, you should be able to find any other places that are not connected. Closed areas will turn light blue.
