Issue with Resizing a Rectangle in CAD – Top and Bottom Move Symmetrically
lukasdobis
Message 1 of 8
lukasdobis
Hello, I need some help with something that seems really simple, but I just can’t figure it out and I’ve been stuck on it for hours. I’m modeling a screwdriver holder for my desk. Since I didn’t know the exact dimensions, I started with a 2-point rectangle, extruded it into 3D, and then added other features. Now that I have a rough model, I want to scale it down.
I know there are two options:
  1. The easiest way would be to remove material using the extrude tool, but I don’t want to do that.
  2. The second option, which seemed simple but where I got stuck, is to resize the rectangle.
I split it vertically into two parts and aligned them to the center. I adjusted the left and right sides individually, and now I want to adjust the height from the center as well—but it doesn’t work. Both the top and bottom edges move symmetrically, and I don’t understand why. I intentionally didn’t use a center rectangle at the start because I expected this issue, but I didn’t think it would happen with a regular rectangle. I didn’t set the top and bottom edges to be equal, only parallel, so I really don’t get what’s causing this. Thanks in advance!
My plan was to create a cross inside the rectangle, constrain it with right angles, center it in the sketch, and then adjust each side individually, simply put.
Replies (7)
Message 2 of 8
g-andresen
please share the file for reply
File > export > save as f3d on local drive > attach to post
günther
Message 3 of 8
lukasdobis
Here is
Message 4 of 8
g-andresen
delete midpoint constraint
(view in My Videos)
günther
Message 5 of 8
jhackney1972
Take a look at the attached video.
If this answers your question, please select the "Accept Solution" on my post. If you need further help, please ask.
(view in My Videos)
John Hackney, Retired
Message 6 of 8
lukasdobis
Thanks  jhackney1972 and g-andresen all what is that triangle and why he put there automatickli ?
Message 7 of 8
jhackney1972
Who is "he"?  Some sketch constraints are applied automatically if the condition is met.  You can prevent these automatic constraints by holding down the CTRL key (Command) key when sketching.
Message 8 of 8
lukasdobis
Sorry, I am not a native English speaker. Thank you for your answer and explanation
