Issue in exporting multiple bodies
m.savazzi
m.savazzi
I have multiple separated objects that I need to export as one stl.
if I select them I DO NOT have the option to export
If I do a rigid group I connot export the group.
How can I do it?
I've checked:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
and
and they DO NOT WORK!
I do not have the export STL menu item
M
paul.clauss
Hi @massimoPXW7C
Thanks for posting! If you have multiple bodies or components selected when right clicking you will not see the "Save as STL" option.
The key here would be to create all the components to be printed together in the same component. To work around this, you could copy the bodies you would like to export as an STL to a new component and then use the Save as STL command on the parent component. I've shown this in the screencast below.
Please let me know if you have any questions.
Paul Clauss
Product Support Specialist
nchasen
Community Visitor
Community Visitor
This is not working for me in the current version. Save as STL is not available for the model as a whole or the component i generated with my multiple bodies. It is only available when selecting individual bodies.
Is there a new method to accomplish this?
