Internal Solver Error When Solving Static Stress Simulation
david
david
I have what I'd like to think is a simple model. I first ran a Shape Optimization and now I want to validate my changes with a Static Stress simulation. My Pre-Check is clear. When I solve using the cloud, I eventually receive an Error: Internal Solver Error with no explanation. How can I debug this? I also included a screenshot from trying to run this locally.
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @david
I'm sorry to hear that. It rarely happens when you receive the results from A360 server.
I tried to run your file and it was succeed.
Have you seen this article?
Fusion 360 internal solver error : https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
Please try the workaround if you can't resolve it, please let me know.
I'm sharing the file succeed with running so please find it. Smiley Happy
Many thanks,
Ahreum.
david
I exported a f3d and re-uploaded it. I still cannot run the analysis.
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @david
I'm sorry about it. It turned out that is a known issue regarding bolt connector. the development team are working on int. (ARRO-8808)
As a workaround, I found this thread. could you try this?
https://forums.autodesk.com/t5/inventor-forum/fea-on-bolted-structures/td-p/2799242
Sorry for the inconvenience caused. Smiley Sad If I receive any response, I will get back to you
Many thanks,
Ahreum.
