Integer Value in Parameter
hdvideo2015
hdvideo2015
I want to use a parameter when entering number of holes in a rectangular pattern. The formula I want to use is floor(OverallLength/60).  The function returns the correct value, but only if a unit is defined.
For it to work in the Rectangular Pattern Quantity field, it needs to be an integer with no units defined.
Is there a way to use the floor() function in a parameter with No Units?
Thanks, Ed
HughesTooling
If I understand correctly just divide by your units, this should work, floor(OverallLength/60) / 1mm, or 1in if you are working in inches.
Or you can shorten it to floor(OverallLength/60mm)
Mark
Mark Hughes
Owner, Hughes Tooling
hdvideo2015
That did it - Thanks!
m.hofmannCBJWH
Community Visitor
Community Visitor
m.hofmannCBJWH
Community Visitor
Community Visitor
thanks
