Installation Error
Installation Error
Amorphis984
Installation Error
Amorphis984
After experiencing problems when attempting to render a model, I uninstalled Fusion 360, downloaded a fresh version, and attempted to re-install. However, I received an error saying that “Something went wrong” and it was unable to reinstall Fusion 360.
I downloaded the log file which was produced after the installation failed.
g-andresen
Did you use  CLEAN UNINSTALL?
günther
Amorphis984
No, but I'm reading about it and downloading the utility.
g-andresen
only with the tool you get a clean base for the reinstallation.
günther
Amorphis984
I downloaded the Fusion 360 Cleaner and ran it. After running it produced the massge that it completed successfully. However the log file it produced says otherwise.
Amorphis984
How do I get phone support to fix my problem?
jhackney1972
Your log file indicates you are having a Network Socket issue.  I have seen this solved by either restarting your internet router and/or connecting directly to the router with a network cable, getting off of Wi-Fi during installation.  Here is an Autodesk article mentioning Socket errors.
John Hackney, Retired
