Inspect tool fail
Inspect tool fail
Inspect tool fail
I want to know the distance of the red line but I cant do it with the inspect tool, am I being the moron or is fusion just retarded?
ian1196
I get similar issues. Sometimes, I just have to draw a line and measure the line.
jeff_strater
The Measure command can only measure selectable objects in the model.  Section views like this produce visual effects only, it does not change the model.  So, even though it looks like there is a partial edge in the model, it doesn't really exist.
Jeff Strater
Engineering Director
Thanks for the reply. I dont want to measure the section point. The edge to edge I want to measure is actually there. why on earth cant i see the horizontal and vertical distances between the 2 lines?
Kind regards
Michael Mullineux
alex65HMP
Community Visitor
Community Visitor
Hi, I'm having the same issue, check out my attached image.  I opened a dwg file, measure a line with the Fusion Inspect Tool, but the result is clearly wrong.  I measured the exact same line on another day, the measurement was correct, but for some reason, today the result is more than doubled!
