Insert SVG Locking Up and Crashing
hankmcknight
Message 1 of 11
hankmcknight
I am trying to insert a .svg file that is 859kb.  It will insert after a while but after I get the size I need it just locks up when I try to extrude.  It is a deer scene wall clock to be cut out on my cnc router wanting it to be 25" x 15".  I have included the .svg file.
Hank
Accepted solutions (3)
Replies (10)
Message 2 of 11
ryan.bales
Autodesk Support
Autodesk Support
The short answer is that this SVG will run poorly. There are 26000 lines in the single sketch. Many of which are nearly zero length segments. This also results in about equal points at 26000. Meaning you have a massive sketch with a ton of objects. Its possible that you could clean this up in Fusion, but its sketching engine really isn't designed for cleaning up 2D line work and sketches like this. (it lacks simplification tools and those that can combine large quantities of objects and purge null or nearly null segments/points - many in this sketch are lines at .001" long)
Disabling profiles will help, but i'll be honest, this design needs AutoCAD, not Fusion 360 to clean up first. Even when or if you get the sketch working, that many lines and points in CAM will likely cause contour selection problems and overall finish on a CNC router may be poor. I can try to look at it in AutoCAD and see if it can be cleaned up in a bit.
Ryan Bales
Fusion 360 Product Support
Message 3 of 11
g-andresen
I converted the file to Bezier with V-Carve.
Try it.
günther
Message 4 of 11
g-andresen
In my view, fusion is only "suboptimal" for such tasks. I say this although I have been a convinced Fusion user for more than 6 years.
Applications like Artcam or V-Carve were developed for this purpose. Artcam was taken out of the race by Autodesk, so that as far as I know, only V-Carve currently meets the requirements.
günther
Message 5 of 11
ryan.bales
Autodesk Support
Autodesk Support
I totally agree with that @g-andresen, i think the hard part is it wasn't ever designed for it.
Speaking as Ryan the user and not 'Ryan at Autodesk' I hope someday we can get some validation and sketch cleanup tools in there.
Ryan Bales
Message 6 of 11
hankmcknight
Thanks for the replies I did not receive an e-mail that anyone responded.  Just happened to be looking around today and found the responses.  I will try the V-Carve conversion tonight.  I really like Fusion 360 it's just not working on this.  I can open and make my g-code in Estlcam but I want to change the clock face which I have been able to do now but when I Extrude it just crashes the program.  Being that I am using as a Hobbyist I can not export in a format that Estlcam or any of my programs can use.
Message 7 of 11
hankmcknight
Thank I will try tonight.
Message 8 of 11
g-andresen
The basic problem is too high a level of detail in vectorisation.
The development is shown here.
Even with a tolerance of 1mm, some manual work is still necessary, especially on the right side.
günther
Message 9 of 11
hankmcknight
Thank again just wanted to make sure I was not doing anything wrong.  Did I understand that I would be able to work with it in VCarve?
Message 10 of 11
g-andresen
@hankmcknight wrote:
...  Did I understand that I would be able to work with it in VCarve?
Yes!
günther
Message 11 of 11
hankmcknight
Thanks for all your help.  I guess VCarve it is.  I will subscribe tonight.
