Insert Fastener Command
wbarszcz52FXF
wbarszcz52FXF
Hi, I have encountered a problem with opening the Insert Fastener Command. Few hours ago I was normally using this function to load and use DIN screws on my model. Now it has problem with loading. I read literally every forum I have found and there is no such a problem and no solution to it. Maybe someone had similar problem. ( Apologize for polish text in the photo)
Regards
jhackney1972
Have you closed Fusion and reopened it?  This was a brief problem last week but has been fixed.  If you have not restarted Fusion since the occurrence,  this may help.
John Hackney, Retired
wbarszcz52FXF
Of course, I have restarted either program in processes and my PC multiple times , and non of those helped with the issue
Roman_Vesely
Hi wbarszcz52FXF,
 we are very sorry that you have a problem with accesibility of Insert Fastener command.
Last week we have released September 17 major update with build 2.0.20256 , could you try to update your Fusion and start Insert Fastener command again, please ?
Regards
 Roman
Roman Vesely
Inventor - Principal QA Engineer
