IndexError - Reinstall Fusion360
nhartman5RT96
Observer Observer
Message 1 of 10
nhartman5RT96
Observer
Observer
Hye Guys! Needs some help been trying to update then tried to reinstall fusion360 and keep having issues. Please advise, thanks!
Traceback (most recent call last):
  File "R:\Streamer\src\adsk\dls\streamer\process\process.py", line 1133, in execute
  File "R:\Streamer\src\adsk\dls\streamer\process\process.py", line 1080, in execute_without_errorhandling
  File "R:\Streamer\src\adsk\dls\streamer\process\process.py", line 906, in _config_app
  File "R:\Streamer\src\adsk\dls\streamer\process\process.py", line 1842, in _do_installation
  File "R:\Streamer\src\adsk\dls\streamer\process\process.py", line 1603, in wait_threads
  File "E:\Jenkins\3P\PYTHON\3.9.6\WIN64_1\lib\concurrent\futures\thread.py", line 52, in run
  File "R:\Streamer\src\adsk\dls\streamer\process\process.py", line 1723, in execute_tasks
  File "R:\Streamer\src\adsk\dls\streamer\process\process.py", line 403, in _executetasks
  File "R:\Streamer\src\adsk\dls\streamer\windows\platform.py", line 320, in create_launch_items
  File "R:\Streamer\src\adsk\dls\streamer\windows\platform.py", line 419, in _manipulate_shortcuts
  File "R:\Streamer\src\adsk\dls\streamer\manifests.py", line 807, in walk_external_references
  File "R:\Streamer\src\adsk\dls\streamer\windows\platform.py", line 376, in __filevisitor
  File "R:\Streamer\src\adsk\dls\streamer\manifests.py", line 62, in __next__
  File "R:\Streamer\src\adsk\dls\streamer\manifests.py", line 44, in _manifestvalfor
  File "R:\Streamer\src\adsk\dls\streamer\manifests.py", line 239, in _process_template_value
  File "R:\Streamer\src\adsk\dls\streamer\utils.py", line 259, in __call__
  File "E:\Jenkins\3P\PYTHON\3.9.6\WIN64_1\lib\string.py", line 121, in substitute
  File "E:\Jenkins\3P\PYTHON\3.9.6\WIN64_1\lib\string.py", line 114, in convert
  File "R:\Streamer\src\adsk\dls\streamer\manifests.py", line 228, in __getitem__
  File "R:\Streamer\src\adsk\dls\streamer\configuration.py", line 782, in __getitem__
  File "R:\Streamer\src\adsk\dls\streamer\windows\platform.py", line 1969, in __getitem__
  File "R:\Streamer\src\adsk\dls\streamer\platform_base.py", line 104, in __getitem__
IndexError
Replies (9)
Message 2 of 10
RajkumarIlanchelian
@nhartman5RT96 Can you please try the below?
1. Make sure that Fusion installer is not running in task manager
2. Go to C:\Users\user\AppData\Local\ DELETE folder Autodesk\
3. Do not use the same Fusion installer. Can you please download the installer again? (make sure that 360 is not found in the installer name)
4. Now install again
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 10
nhartman5RT96
Observer
Observer
Thank you sir! Worked perfectly!
Message 4 of 10
juergen.belle
Community Visitor
Community Visitor
Hello, for me it didn't work, same error again...
2024-06-04 14:02:38,504 - MainProcess(1240) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
File "R:\src\adsk\dls\streamer\process\process.py", line 1186, in execute
File "R:\src\adsk\dls\streamer\process\deploy_process.py", line 95, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 1116, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 932, in _config_app
File "R:\src\adsk\dls\streamer\process\process.py", line 1931, in _do_installation
File "R:\src\adsk\dls\streamer\process\process.py", line 1692, in wait_threads
File "E:\Jenkins\3P\PYTHON\3.11.1\WIN64_1\Lib\concurrent\futures\thread.py", line 58, in run
File "R:\src\adsk\dls\streamer\process\process.py", line 1812, in execute_tasks
File "R:\src\adsk\dls\streamer\process\process.py", line 415, in _executetasks
File "R:\src\adsk\dls\streamer\windows\platform.py", line 344, in create_launch_items
File "R:\src\adsk\dls\streamer\windows\platform.py", line 444, in _manipulate_shortcuts
File "R:\src\adsk\dls\streamer\manifests.py", line 807, in walk_external_references
File "R:\src\adsk\dls\streamer\windows\platform.py", line 398, in __filevisitor
File "R:\src\adsk\dls\streamer\manifests.py", line 62, in __next__
File "R:\src\adsk\dls\streamer\manifests.py", line 44, in _manifestvalfor
File "R:\src\adsk\dls\streamer\manifests.py", line 239, in _process_template_value
File "R:\src\adsk\dls\streamer\utils.py", line 258, in __call__
File "E:\Jenkins\3P\PYTHON\3.11.1\WIN64_1\Lib\string.py", line 121, in substitute
File "E:\Jenkins\3P\PYTHON\3.11.1\WIN64_1\Lib\string.py", line 114, in convert
File "R:\src\adsk\dls\streamer\manifests.py", line 228, in __getitem__
File "R:\src\adsk\dls\streamer\configuration.py", line 782, in __getitem__
File "R:\src\adsk\dls\streamer\windows\platform.py", line 2068, in __getitem__
File "R:\src\adsk\dls\streamer\platform_base.py", line 108, in __getitem__
IndexError
Pleas help!
Message 5 of 10
RajkumarIlanchelian
@juergen.belle Are you still facing this issue? After closing Fusion and making sure that it is not running task manager , can you also restart your machine?
Autodesk Fusion
Join Fusion Insider
Message 6 of 10
juergen.belle
Community Visitor
Community Visitor
@RajkumarIlanchelian No, still not work:
2024-06-13 16:13:20,654 - MainProcess(9712) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
File "R:\src\adsk\dls\streamer\windows\platform.py", line 401, in __filevisitor
IndexError
Message 7 of 10
RajkumarIlanchelian
@juergen.belle Do you have this folder in this location?
Can you please also do the below?
1. Close Fusion
2. DELETE the Fusion shortcut that you use to launch the product
2. Go to add/remove programs
3. Select Autodesk Fusion - MODIFY
4. This will launch the service utility
5. Run the repair Fusion
Now launch Fusion. Does that help?
5. Run
Autodesk Fusion
Join Fusion Insider
Message 8 of 10
jfgass83
Community Visitor
Community Visitor
This is terrible advice!  Do NOT do this. I deleted the folder as suggested and now I can't modify or uninstall the program at all.
Message 9 of 10
RajkumarIlanchelian
@jfgass83 Not sure what errors you are facing but after deleting that folder, delete the short cut that you use to launch Fusion. Now simply reinstall using the installer and that should get you back.
Autodesk Fusion
Join Fusion Insider
Message 10 of 10
aadavis2
Community Visitor
Community Visitor
Worked for me too, thanks!
