Incorrect drawing values
n.cherkasovH7XGC
n.cherkasovH7XGC
I have the same strange issue on 2 objects now. There is a simple geometry with round dimensions. Say, a cylinder 24 mm in diameter.
Then I create a drawing, a cross-section. The diameter of this item ends up being 23.99 mm. And I see it in a few occasions. I can see it in cross-sections of perfectly cylindrical objects.
If I simply type it manually, it pretty much kills the point of 3d-CAD to drawing integration. Is there way to fix this bug?
-KyleWilliams-
Hey @n.cherkasovH7XGC
I've tried to replicate this with a simple 24mm cylinder as you state and I'm not getting the same results.
If you're able to share a file that you're having this issue on that may help us figure out what is going on.
Kyle Williams
Senior Customer Advocacy Manager - Design and Documentation
Ontario, Canada
Become an Autodesk Fusion Insider
g-andresen
Please share the file for investigation.
File > export > save as f3d on local drive  > attach it to the post.
günther
