Imported terminal block STEP file from Wurth Elektronik. JOIN does not seem to work with the whole component (leaving some of the bodies behind).
learner_leung
learner_leung
Community Visitor
Community Visitor
Tried to use JOIN to insert the terminal block into another assembly but was not able to move the whole terminal block as a component (leaving some of the bodies of the terminal block behind).
Please advise on how to use imported STEP file as a whole component.
Thank you very much!
TheCADWhisperer
@learner_leung
Can you Attach your original STEP file here?
jhackney1972
I went to the company website, you specified, and download a STEP file of a connector containing multiple components.  I then save it as a component and inserted it into an assembly.  The video shows you one way you can handle all of the multiple components so they stay together.
John Hackney, Retired
