Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
imported files show up in mm not inches, and scale when I change units
serviceRTDVA
serviceRTDVA
I have all my settings for new drawings, in all areas, set to inches.  I am currently trying to import a .3dm file, which does have unit information, and the model is 1" tall.  When I open it in Fusion, it has changed to 10mm tall.
If I change the units in the drawing to inches, the model is *scaled* and is now .3937" tall.
It seems that Fusion has chosen to import my model as if it were in cm, scaled that to mm, and then scales again when I try to tell it the unit information *that existed in the originally imported file*.
How can I fix this?  Currently I can scale the model, but I have to remember to check the units every time, and it's annoying.  The other posts I have seen about this just talk about changing the units, but I haven't seen anyone mention scaling, so maybe it doesn't happen to other people?  I can't tell.
Thanks for any hints.
jhackney1972
If you use the Export command, the conversion is done by the Autodesk Servers and they only work in Centimeters.  The video will show you a better way that will maintain your units.
(view in My Videos)
John Hackney, Retired
HughesTooling
@jhackney1972  This is about .3DM (Rhino) files.
@serviceRTDVA  Just did a test and if I have a 3dm file set to inches it imports as inches.
Here you can see I've saved a 1 inch cube and it opens in inches and is 1 inch. Try with the temp.3dm file attached.
Mark Hughes
Owner, Hughes Tooling
jhackney1972
OOPS! I read the file type wrong.
serviceRTDVA
Hi Mark, I tried your cube and it imported as a 1" cube.  Makes me suspect an issue with the software I am using to create my .3dm files!  It's something called Moment of Inspiration 3D, and it uses Rhino v5 format.  I will ask on the forums there.
Thank you, that moves me forward with this problem.
@jhackney1972 I appreciate your reply, but it doesn't address my problem.
Best,
Rachel
