Import SVG Freezing
Import SVG Freezing
richardg19001
Import SVG Freezing
richardg19001
Community Visitor
Community Visitor
Hi, having problems importing SVG with the new version of fusion, when i import it just has the spinning wheel, have installed of another laptop, & created a trial account to try but still no luck, so doesn't work on two different computers, two different accounts, clean install & tried different svg, there nothing big, just basic text trying to learn making keyrings etc.
HughesTooling
Can you share the SVG so other people can try?
Mark Hughes
Owner, Hughes Tooling
sameer_babarNJS6C
@richardg19001
Sorry for the inconvenience caused & Thank you for reporting it .
This is known issue (FUS-158616) & our team is looking for the solution .
Sameer Babar.
Autodesk Fusion 360 Team
ilmavaravad
Community Visitor
Community Visitor
@sameer_babarNJS6CAny update or workaround on this issue?
sameer_babarNJS6C
@ilmavaravad  Thank you for your patience.
We have fixed this issue and validation is also done. Very soon we will be deploying this fix .
Sameer Babar.
HughesTooling
If you have a commercial or educational license you can use the online browser version of Fusion to import SVG. This only works because the online version is using on older version of Fusion so could stop working if it's updated. Note, you will need to upload the SVG to a project before opening with the browser version.
This was a test I did a few days ago with an SVG that would not work in the current version but open fine with the browser version.
Mark Hughes
sameer_babarNJS6C
@richardg19001 ,@ilmavaravad
Once again thank you for your patience.
We have deployed a fix for this issue to production with latest update , you can update Fusion to  2.0.19440 version to have this fix.
Sameer Babar.
Autodesk Fusion Team.
