Import Spline CSV script "no valid points"
Message 1 of 25
The ImportSplineCSV script keeps giving me an error message that says "No valid points." I've double checked the format of the csv file: it has about 20 points with X, Y, and Z coordinates and nothing else. Any ideas?
Replies (24)
Message 21 of 25
JeromeBriot
@Protective-foam_comI have just released a new version of the script. Let me know if it works as expected.
Message 22 of 25
Protective-foam_com
@JeromeBriot
It looks like it's not working for me.
I am attaching a test CSV file. Please check based on it.
Message 23 of 25
davebYYPCU
the file attached to this last message, must be an old one, it still has the semicolons. Find / Replace with commas.  Sketches with this many spline points tends to choke Fusion's normal tools.
Might help....
Message 24 of 25
JeromeBriot
Did you edit the script file and set the SCALE_FACTOR variable to 0.1 before running it?
Message 25 of 25
Protective-foam_com
@JeromeBriot
Now it works! Thank you very much.
For other users, I'm uploading a screenshot showing where to change the parameter:
