Import DWG
Import DWG
Cad4fish
Message 1 of 17
Import DWG
Cad4fish
Is the function to import a DWG not available in the free, not for commercial use version?  What I've found in the forums is to upload in the data panel, but I do not see that option.
Replies (16)
Message 2 of 17
jhackney1972
The ability to Upload DWG files is available with the Fusion 360 Personal License.  What you do with it after it is upload is not much.  You cannot open it in Fusion 360 from the Cloud.  You can open it in the Web Database and view it if that helps.
John Hackney, Retired
Message 3 of 17
Cad4fish
If you can't open it to edit I don't see a point.  Fortunately the thing I just drew in NanoCAD is very simple and can be drawn again in F360 in a few minutes.  This part of the data panel does not show up on my computer.
Message 4 of 17
jhackney1972
Some users, including myself, use the Web Database to share files for viewing or distribution only.  You can place many types of files on the Web Database besides CAD data.
Message 5 of 17
Cad4fish
When I searched import DWG to F360 an answer (the only answer) was to use the upload button in the Date Panel.  Answers to other questions implied you could import the object, but not the dimensions.
Message 6 of 17
jhackney1972
With a Fusion 360 Subscription, you can use the Open command, under File menu, and open an AutoCAD DWG file or you can use the Upload icon on the Data Panel.  You are correct, you only get model sketches with no dimensions, if they exist at all.  If your DWG contains a 3D model, it will import as a solid body.  Here is an example of a DWG import on my system.
Message 7 of 17
Cad4fish
I tried uploading the DWG but it I don't see it online.  I saved it as a DXF file and was able to open it.  However I only have a sketch that cannot be extruded.
Message 8 of 17
jhackney1972
If you would like to attach the DXF, I will give it a try for you.
Message 9 of 17
Cad4fish
Attached
Message 10 of 17
jhackney1972
The DXF imported fine except it reported not having any assigned Units.  The Profile has a couple of broken points in it.  If you use "Divide and Conquer" method of diagnosis, it is an easy process to repair.  If you do not know what divide and conguer is, simply edit the sketch, sketch a line diagonally across the sketch, not touching an edges with the endpoints, then move is along to identify the broken points.
Message 11 of 17
TheCADWhisperer
@Cad4fish
Some of your dimensions do not make logical sense to me.
Message 12 of 17
Cad4fish
What happens to alert you to the broken points?
Message 13 of 17
TheCADWhisperer
Edit the sketch and sketch a line across the geometry.
 Note that there is a shaded profile on one side of the line but not the other.
If we move the line note the shaded profiles.
This would indicate that the breaks (might be microscopic) are at these two arcs.
Add the two missing Coincident Constraints and the entire profile now shades...
Message 14 of 17
Cad4fish
The angles are not important.  That top one is interesting.  It was supposed to be 6-5/8.
Message 15 of 17
TheCADWhisperer
@Cad4fish
Edit the Attached to whatever dimensions you need.
Message 16 of 17
Cad4fish
Thanks, but I had already done it from scratch in F360.  Only took a few minutes to redo.
Message 17 of 17
Cad4fish
I created a different item in NanoCAD and saved it as a DXF.  I was able to open the file in F360 but I cannot select it to scale it up.  It's 6" long but came into F360 as 0.2" long.  It's a flat wrench.  I need to be able to make the opening 7/8" wide so I need to be able to select the object and then select two points as the reference distance.
I tried "Sketch.ShowUnderconstrained" and got the message "No active sketch exists".
