I n Ed to cut these timber’s off at the outside edge of the tank how do I do that? I can’t seem...
FacebookGroupMember
Message 1 of 14
FacebookGroupMember
I n Ed to cut these timber’s off at the outside edge of the tank how do I do that? I can’t seem to get the right operation
Replies (13)
Message 2 of 14
FacebookGroupMember
Ever use a sketch and a extrude or split body and delete.
Message 3 of 14
FacebookGroupMember
Daniel Lyall I tried and when I deleted it goes back to a full timber
Message 4 of 14
FacebookGroupMember
Daniel Lyall
Message 5 of 14
FacebookGroupMember
can you post the model
Message 6 of 14
FacebookGroupMember
Daniel Lyall I have no clue how to donthat
Message 7 of 14
FacebookGroupMember
right click on the model in the data panel and select share public link then post that link.
Message 8 of 14
FacebookGroupMember
Message 9 of 14
FacebookGroupMember
Did that work?
Message 10 of 14
FacebookGroupMember
Message 11 of 14
FacebookGroupMember
You need to set it to be downloadable
Message 12 of 14
FacebookGroupMember
It wouldn’t let me with the free copy
Message 13 of 14
jhackney1972
If you do not know how to attach your model, open it in Fusion360, select the File menu and then choose Export and save the .F3D file to your hard drive. Then use the Attachments section of a reply forum post to attach it.  This method works with all Fusion 360 license types.
John Hackney, Retired
Message 14 of 14
FacebookGroupMember
Just sketch an annular shape on the top surface of the slats and extrude cut them off.
