I made a freeform model in fusion and I want to import it in inventor
shaki742545
Message 1 of 10
shaki742545
I made a freeform model in fusion 360, and I want to import it in inventor with the low poly so I can edit it later.
How would I go about doing that?
Replies (9)
Message 2 of 10
TheCADWhisperer
What version of Inventor do you have?
What trouble are you having opening in Inventor (you could always Export as STEP)?
Message 3 of 10
HughesTooling
If you right click the body there is the option to save the control frame to OBJ or save as IGA. Would either of those work?
Mark Hughes
Owner, Hughes Tooling
Message 4 of 10
shaki742545
But how do I import this in inventor?
Message 5 of 10
shaki742545
I'm using inventor 2023. The problem is if I export step, I can't edit it in the "polygon" mode, it would be just a solid not the polygon freeform thing(the purple icon thingy).
Message 6 of 10
shaki742545
this is the f3z file
Message 7 of 10
TheCADWhisperer
@shaki742545
I wouldn't do what @HughesTooling suggests.
I would use >>this technique<< directly
or
use STEP.
Message 8 of 10
TheCADWhisperer
@shaki742545 wrote:
I'm using inventor 2023. The problem is if I export step, I can't edit it in the "polygon" mode...
Why not model using the Form tools in Inventor?
Let me take a look at the file.
Also did you try >>this<<?
Edit: I took a look at your file.  Did you Attach the correct file?  I recommend that you start over from scratch.
Message 9 of 10
shaki742545
I saw this actually, but the link in the page 404ed, and I can't find a download link to the desktop connenctor.
Message 10 of 10
johnsonshiue
Hi! There are some issues with certain Autodesk Knowledge Network pages at the moment. Here is the page you may download Autodesk Desktop Connector.
https://help.autodesk.com/view/CONNECT/ENU/?guid=Install_Desktop_Connector
Many thanks!
Software Test Engineer
