Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
i'm missing half of my extrude drop down.
m_c_debruyn
m_c_debruyn
Community Visitor
Community Visitor
this worked earlier today.  I can't get the emboss part to work.  i get errors because i cant adjust the depth of the emboss.
can someone direct me as to how to get this drop down to work properly again?
davebYYPCU
There is nothing selected.
Tell Fusion what you want from top down, box will add details as you are working.
Might help…..
m_c_debruyn
Community Visitor
Community Visitor
I sent the wrong screen shot.  i had things selected and it wouldnt show up.
HughesTooling
It might be a problem with the font you're using. Have you tried any other fonts and maybe less text? Can you share a file you have a problem with? Export as an f3d
Also don't attach pictures, just paste images into the message or us the photo option.
Mark Hughes
Owner, Hughes Tooling
jhackney1972
Some fonts will not Emboss or Extrude in Fusion.  Try a different font.  Attach you model and let the Forum users take a look for you and be sure to mention the font name you are using.  Fonts do not transfer with the model.
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
HughesTooling
@m_c_debruyn You could also try exploding the text. In sketch edit mode just right click on the text and explode to curves.
Mark Hughes
