I can't shell my boat model
Hi I am trying to shell my boat hull but get an error message for any value under 8mm. I tried to offset the faces in surface mode and they did offset but some in the wrong direction.
can anyone help please?
jean.flower
Hello thrjesse,
I took a look at this.  There is a problem with shelling at the nose of the boat and at the windscreen (do boats have windscreens? I don't know).  The difficulty is that the diffferent surfaces in these areas can each offset but the offset surfaces won't "glue up" to make a watertight sheet.  Cropping these regions away (combine-cut) leaves an adjusted boat shape which will shell to, say, 2mm.
I imagine that you don't want a boat that's this shape; you need that nose shape as you designed it on the outside of your shell but maybe it's not so important what the shape of the inside is.
I started to put together a longer timeline to demo how to build a model with your boat as the outside and the adjusted inside shape (I would offset a surface model and then use that offset surface body as a tool for split-body), but I decided to hold off - I'm not sure what thickness you're really after, or what shape you want around the top of the boat - do you have an idea of some "open faces" for the result you seek?  Or are you seeking a complete hollow boat with a void space inside?
Jean Flower
Product Manager
Autodesk, Inc.
hi thanks for your time.
I am aiming for a large opening in the top of the boat. I have adjusted a lot of the top section that was giving me trouble an have finally found a shape that shelled to the 1.2mm I was looking for.
it looks a bit different now but that is not too critical.
I think it will still do the job. I may try to introduce the elements that Iboat hull 4.PNG had to remove later and see how that goes.
thanks again.
jean.flower
Thanks for the update!  Glad you found a way to get to the shell.
Jean Flower
Product Manager
Autodesk, Inc.
