I can no longer export a file
OopsieP77GL
Message 1 of 175
OopsieP77GL
I haven;t been able to export a file from the app in weeks now. The app will stop responding. I have to close it through task manager and get the file from web.
Replies (174)
Message 21 of 175
OopsieP77GL
This my also be interesting. This is task manager after I restarted my pc, opened Fusion and drew that box as previous message.
Message 22 of 175
OopsieP77GL
So once more I removed all autodesk related software. I removed appdata and even went in registry and removed everything found on Fusion360.
I completely shutdown my computer, restarted again.
Downloaded a fresh install file fusion 360 and installed it. No icons shown,
Then I created a simple box, once again.  Saved it.
Notice the blue wheel spinning....
Trying to export as DWG. works.
Exporting as STL ... hangs and not responding,
Taskmanager
Message 23 of 175
OopsieP77GL
Working offline same problem.
Message 24 of 175
OopsieP77GL
Also disabled my firewall.
Message 25 of 175
Claes_Bengtsson
I have the exact same problems, no thumbnails, upload never finishes and printing function to slicer not working and hanging the computer.
I hoped the last update (20460) would solve the problems. But No.
Message 26 of 175
OopsieP77GL
Fun fact: I just created another user on my PC and installed Fusion there with a free personal use account. I have no problems on that one.
Of course it's not the way I want to work with Fusion, but its better than not working at all.
Message 27 of 175
jpk5z
Hello @RajkumarIlanchelian
I followed your instructions to delete the  login__ActiveDocuments  and that did remove the continuously uploading design, it seems to be completely gone now, so thank you for that.
Unfortunately, all the other behavior remains.  I can't export/save any mesh files (in any format), I can't send files to any print programs (I assume that just makes an STL anyway), I can't export/import/insert STEP files (including through the Mcmaster option).
All of these actions must be doing some common network activity that's hanging.
Message 28 of 175
RajkumarIlanchelian
@OopsieP77GL On this new user account did you use the trial version account of Fusion to login? If it is working in another user account and not in your then at least it is very specific to this user environment. This helps it at least narrow it down to likely some settings that is blocking it in that user environment. I thought you mentioned this but did you disable windows defender and see what happens?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 29 of 175
RajkumarIlanchelian
@jpk5z Just like the other user on this thread, if you don't mind can you create a another user account on your machine and see if that works correctly? In your current user account can you please disable windows defender and see if that helps to narrow down where this is getting blocked?
Autodesk Fusion
Join Fusion Insider
Message 30 of 175
OopsieP77GL
No, I created an entire new user. Really from scratch. No Trial., nothing.
If only I could remove everything completely on my main user account, but   whatever I do i keep seeing things in recent data that i can not delete.
Message 31 of 175
OopsieP77GL
By the way, these recent files can not be found online.
Message 32 of 175
RajkumarIlanchelian
@OopsieP77GL Can you please invite me into this team hub? [email protected]
Autodesk Fusion
Join Fusion Insider
Message 33 of 175
RajkumarIlanchelian
@OopsieP77GL Also please do the following:
Close Fusion
  1. Uninstall Fusion, then:
  2. Go to C:\Users\user\AppData\Local\ DELETE folder Autodesk\
  3. Delete your Fusion launcher shortcut
  4. Download the installer again
  5. Now install
Autodesk Fusion
Join Fusion Insider
Message 34 of 175
OopsieP77GL
I am trying (im a noob, forgive me) but  I can not enter anything here. Also, it is hanging in refresh.
Message 35 of 175
OopsieP77GL
I have done that multiple times, deleted the entire appdata folder, but i will do that again,
Message 36 of 175
RajkumarIlanchelian
@OopsieP77GL use the web interface to do the invite.
Autodesk Fusion
Join Fusion Insider
Message 37 of 175
OopsieP77GL
its not letting me
Message 38 of 175
RajkumarIlanchelian
@OopsieP77GL So this one shows that you are an editor role in this hub. Interesting that you are not an admin in this hub. It looks like a lot of things going wrong with this trial account. Let me use this email that I see in there and check in the back end.
Autodesk Fusion
Join Fusion Insider
Message 39 of 175
OopsieP77GL
In the meantime I have completely removed autodesk Fusion 360, restarted my computer, removed appdata /roaming etc.
Message 40 of 175
OopsieP77GL
If needed you can cancel any trial, personal use is fine. I just use it for my hobby.
