How to select center of mass?
Alec_Mallinger
Message 1 of 9
Alec_Mallinger
Hi, I need to select center of mass, yet there is no way that I have found yet that allows me to do so. I have the center of mass on the object, I just need to be able to actually select it as a point. Is this possible?
Replies (8)
Message 2 of 9
ryan.bales
Autodesk Support
Autodesk Support
It's mostly specific to whatever function you are doing. What are you selecting it for?
On trick on something like Inspect > Measure is to use click-and-hold to bring up the selection window. Then you can pick it no issues. It's also selectable in the browser as i have it shown expanded:
Ryan Bales
Fusion 360 Product Support
Message 3 of 9
Alec_Mallinger
Hi, thanks for that, but is there any way to select it as a point for a sketch?
Message 4 of 9
ryan.bales
Autodesk Support
Autodesk Support
Not directly no, you'd need to pull the data manually and create the plants/axis/points etc.
To my knowledge its still mostly a visual reference and a dimensional point. @jeff_strater  is this still correct?
Ryan Bales
Message 5 of 9
jeff_strater
Correct, the current center of mass icon is very limited - you can see it, and use it in Measure, but that's the extent of it...
Jeff Strater
Engineering Director
Message 6 of 9
hpekristiansen
Message 7 of 9
jhackney1972
I ran across your forum post where you desired to place a point on the center of gravity (COG) of a body or component.  I recently wrote and recorded a blog article where I do this very operation.  I would like to invite you to take a look at the article and video.
John Hackney, Retired
Message 8 of 9
nomiakasu
Implementing solution would be ideal. A simple point created at the COM icon should be trivial to code and very helpful.
Message 9 of 9
_ritchie
Bump on this from 2025 (!). @ryan.bales or @jeff_strater is it still not possible to bind a sketch point to the dynamically generated CoM for use later in the timeline? I understand and accept that subsequent operations could change the CoM.
