How to Select a Sketch Object?
akerezy
Message 1 of 12
akerezy
 I am soOOOOOoOOOo frustrated after spending SIX HOURS to do something that in every other Windows software, takes seconds....
WHY is it so hard to select a sketch object
I have a screencast below - you can watch me drag a box around a square sketch on the face of body.
You can see it's highlighted, which in every other software on the planet means it's selected, but in Fusion obviously means nothing.
How do you select a sketch object and know without a doubt it's selected?
Why is it so difficult, and why doesn't it work the same way as all other windows software?
Churned in Charlotte
Replies (11)
Message 2 of 12
HughesTooling
You are not selecting the sketch object, you are selecting the profile. The profile is an enclosed area fusion expects you to extrude, press pull etc.
If you want to select all the curves forming a profile you can window select or if all endpoint are coincident you can double click a curve and the chain will select. Rather than waste your time getting frustrated why haven't you done some of the tutorials or looked through the help, in six hours you could learn a lot.
Try starting here.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 12
akerezy
I appreciate your help. In fact I've spent HOURS and HOURS watching YouTube videos on Fusion 360.
Where then in the side menu (perhaps under the sketch object) is the profile object?  There must be such an object because you said it exists - but why don't we see it in the side menu. Is it a "secret" object? Why the mystery? I bet in something like oh say, Solidworks there's no "profile" object? Does Google Sketchup have a profile object?
My point STILL STANDS; I should not have to spend hours watching videos - highlighting an object in ANY windows software should work the same; rather than making it more complicated than it needs to be.
If a profile object and a sketch object are two different things, it should totally obvious in the software.
Message 4 of 12
davebYYPCU
Thank you for the colourful rant - just what I needed to start the day, still chuckling, see below.
you would have a valid point if you had read the three page thread on this subject before the rant,
Some Windows Expert you are,
it’s Control C, deselect the articles
then Control V.  You are given the triad to move in the same sequence.
Both functions are in the Right Click Menu, If you can’t handle a keyboard.
Selected 8 - four lines and four points - cad articles
Whilst not defending AD, your process works for everything other than Sketch articles.
Have a good day, dude.
Message 5 of 12
davebYYPCU
Not sure what to say now, was so used to the older way to get it done, never looked for the copy box in the dialogue, but I have got it in the 2.0.5301 version.
weird.
Message 6 of 12
HughesTooling
If you have spent hours watching youtube videos and still don't know what a profile is you have either been watch bad videos or you might be wasting your time trying to learn CAD. CAD is not as simple as a word processor and will take time to learn, yes there are simple CAD programs but the more simplified the program the less it can do, you might not like it but that's life. As for your question about Sketchup and Solidworks, don't know anything about sketchup but newer versions of Solidworks have a similar ability to extrude any closed area in a sketch. Don't know if they call them profiles @TheCADWhisperer might know, selecting the closed are would more than likely give the same results as Fusion. I'd guess Inventor's the same.
Profiles are any closed area, in the image below there are 9 individual profiles add a few more lines you'll get into hundreds or thousands so having them listed somewhere would be pretty useless. Also they're no secret, as soon as you run a command like extrude, loft, etc. you are prompted to select profiles, you should have picked this up from any of the basic tutorials.
Mark Hughes
Message 7 of 12
HughesTooling
weird.
Just a note on the image above. You only get the Copy option if you are in sketch edit mode, if you've closed the sketch and select the curves and points you can only Move. Not really a good to modify sketches outside of sketch edit mode though. Using Ctrl+C and Ctrl+V is more useful as you can make multiple copies from one selection.
Mark
Mark Hughes
Message 8 of 12
TheCADWhisperer
In your video - you are not in an Active Sketch.
Think of sketches as similar to individual Microsoft Power Point slides.
Right click on your sketch in the browser and select Edit Sketch.
Message 9 of 12
TheCADWhisperer
Somebody figured out a couple of years ago that the world isn't flat...
Message 10 of 12
jeff_strater
@akerezy - you posted this in two different areas:  There is other discussion on this thread:  sketch-object-move-copy-still-not-working-easily
Jeff Strater
Engineering Director
Message 11 of 12
davebYYPCU
Thanks for that little tip,
I am mostly using multiple pastes,
good to know that little gotcha in advance.
Message 12 of 12
TheCADWhisperer
@akerezy
Are you still experiencing issues with copying a rectangle?
Can you File>Export and then Attach your *.f3d file here that is exhibiting this behavior?
