How to scale down hole matrix pattern while preserving hole diameters?
boodecompany
Observer Observer
boodecompany
Observer
Observer
I have a sketch with a matrix of holes of varying diameters (see attached image). I need to compress/scale down the overall size of this pattern to fit in a smaller area, but all hole diameters must remain exactly the same size. Standard scaling doesn't work as it affects the hole sizes too. Looking for an efficient method that maintains: All original hole diameters Relative positioning of holes Center point of matrix
Any suggestions for the quickest way to achieve this in Fusion 360?
TheCADWhisperer
@boodecompany
Indicate the desired scale factor.
boodecompany
Observer
Observer
Hi and thanks for replying, Please see attached
The scale factor should be 0,5 (while diameters of holes should remain the same, for example 40 mm for reference for some of the holes)
Thanks again
