How to save setups
How to save setups
inflameWBW5X
How to save setups
inflameWBW5X
Hi, I'm fairly new to fusion.
I am in the process of revamping my kitchen cupboard doors and drawers by cnc cutting a simple single v groove pattern around the front face of each.
I have also modified a taper tool (in fusion) to match the v router cutter I will be using.
All door and drawer fronts are different sizes in x and y, but the only difference between each item is the toolpath position. They are all 16mm thick and all will be cut to the same depth.
So the question is : How do I save the toolpath setup and the tool I modified, so I don't have to go through all that with  each one ?
jhackney1972
It seems to me that your want to use the "Save as Template" function.  Take a look at the Screencast and see if this will help you out.
John Hackney, Retired
inflameWBW5X
Oh wow I didn't see that in there.
That's excellent. I'll try it out and see what happens, but from what you showed me I'd say it's exactly what I need.
Thank you so much.  I'll come back if there's a problem.
Cheers
