How to save a custom title block?
vid.kok
Message 1 of 23
vid.kok
When I am in drawing workspace and I create a new title block it is only visible within that very drawing. And if I close the drawing and the title block was not used it gets deleted. My question is how to create a custom block title by modifying the defult one and saving it, so I can use it in future projects.
Replies (22)
Message 2 of 23
sandris.vitolins
File -> Save as -> Drawing Template (.f2d)
Message 3 of 23
sandris.vitolins
If you create from "New Drawing Template", then just save it and it will save as drawing template. If you are using "From Design", then "Save As" -> "Drawing Template".
Message 4 of 23
vid.kok
I am probably doing something wrong because I just cannot get it to work.
Can you please explain to me step by stap how to do it?
I basically want an option to switch from default ISO title block to my custom title block (see the image).
Message 5 of 23
g-andresen
1. create a 2. sheet
select your template for sheet 2:;
3. activate sheet 1  > titleblock > your titleblock will be shown in the screencast above
günther
Message 6 of 23
vid.kok
I followed your steps but it doesn't work. I only get two options when I create a drawing which are "From Scratch" and "Browse".
Message 7 of 23
vid.kok
I noticed that a template can be used if it is in the same folder as a design which is a source file for the drawing. Is that normal because it seems rather unpractical to have sepparate copies of the same templates in each folder.
Message 8 of 23
g-andresen
The template is located as f2d in a folder in the data panel.
This does not have to be the folder where the design is located.
It is created via File .. and saved there.
In the GIF I show how a new template can be added and used for other sheets.
add sheet with new templateadd sheet with new template
günther
Message 9 of 23
vid.kok
Thank you for the help.
Unfortunately I cannot claim that I understand the logic but after hours of trying I somehow made it to work.
Do you have a separate project folder where you keep your templates?
It would be much better in my opinion if one could simply upload a template into Assets folder and pick the right one when creating a new drawing.
Message 10 of 23
g-andresen
The procedure for using individual title blocks is actually somewhat tricky.
The process:
1. you create a new template via File > New Drawing > New Drawing Template.
2. sheet settings > Title block > add title block
3. from current or create new >> name for new title block!! *
4. save with "template name" in a folder for templates .
Important: Title blocks are not saved separately but are always bound to a template.
* The names of title blocks do not have to be identical with the names of the template.
The embedding into a new drawing is described above.
regards
günther
Message 11 of 23
royshearer
This is very difficult to get a a working understanding of.
Am I right in thinking that once the template has been used to make a new drawing, there is no link between the template file (and thus its title blocks) and the new file? I ask because I notice that changes in the title blocks in my templates don't seem to propagate to existing drawings made using those templates.
In other words:
'Title blocks' are a subset of 'Drawing templates'.
'Drawing templates' are not a subset of 'Drawings'.
When a Drawing is created from a template, the 'Drawing template' including 'Title blocks' is copied into the 'Drawing'.
Message 12 of 23
g-andresen
Yes, a saved change in the f2d template does not trigger an update action (yellow triangle).
Only when on the way:
Add sheet & select the modified template & "Change Titleblock" the template will be transferred to another worksheet in the modified form.
günther
Message 13 of 23
royshearer
I'm sorry I don't understand your second point there.
I just tried this and it did not behave correctly:
My alternative title block is present in my template, and works fine
when I create a new drawing: I can select between the two title blocks
using the dropdown menu in 'Change title block'.
If I take an existing drawing and add a new sheet, using the same
template as a template, the second title block does not appear in the
'Change title block' dropdown menu.
Message 14 of 23
g-andresen
That´s right.
A title block is bound to the template and thus only available via a new template.
Change Titleblock in Existing Drawing:
1. Add sheet & select the modified template "Sheet 2)
2. Leftclick "Sheet 1" > "Sheet Settings" > Titleblock > Change Titleblock > Menue "Sheet Settings" > select TB
günther
Message 15 of 23
royshearer
I'm sorry I'm not understanding that wording - can you break it down a bit more?
Not sure what you mean by 'new template' in that context?
Message 16 of 23
g-andresen
look at edited  # 14
günther
Message 17 of 23
royshearer
OK, I think you've maybe got sheet 2 and sheet 1 mixed up there but it sounds like you are describing the second method I was referring to.
I have made a screencast to show what I'm meaning. I think you may understand already what I'm meaning, but I don't understand why the two methods create different results.
In both the workflows I am describing, I am using 'change title block' AFTER the drawing sheet has successfully been created from the exact same template file. What I don't understand is why the different methods of creating the drawing sheet should result in different options for titleblocks (ie. using 'new drawing' from a 'design' and selecting the template file vs. using 'new sheet' from a 'drawing' and selecting the same template file).
1e9cb4d2-8ec8-4d1d-bf31-e53a41b1e29c,640,650
Message 18 of 23
royshearer
The forum is not letting me embed a screencast - says it is invalid html.
Here is the link:
https://knowledge.autodesk.com/community/screencast/1e9cb4d2-8ec8-4d1d-bf31-e53a41b1e29c
Message 19 of 23
g-andresen
As I wrote above, it's a little tricky.
Try not to use the Quick Add method but like I showed it in # 8 in the GIF:
> Right Click > ADD SHEET.
günther
Message 20 of 23
royshearer
Yes, that is what I am doing, see the video.. in #18
