How to move the light source to the point of view?
themetricguy
themetricguy
I've tried all the environment settings but these just are not good. The problem is that a light source is not directed from the point of view, hence most of a time part of model appears too dark. It would be great to move the light source  so that it is directed from the point of view onto the model. That way no dark areas would appear on the model. Is there way to achieve that?
James.Youmatz
Autodesk Support
Autodesk Support
Hi @themetricguy,
Have you tried positioning the environment in the Scene Settings? If you move and rotate the scene, you can generally get a better indication of shadows/etc.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
James Youmatz
General Adoption Manager | Informed Design
themetricguy
Hi James, Thank you for the reply. I couldn't find Scene settings in the Model view. It seems these are only for Rendering. I was referring to the Model view with Visual Style set to Shaded (with visible edges only).
James.Youmatz
Autodesk Support
Autodesk Support
Hi @themetricguy,
Ah, I see. In Model, the only ways I am aware of is to change the environment to something brighter such as Photo Booth, as well as to toggle some of the Effect settings. Does it still appear very dark for you while doing that?
James Youmatz
James.Youmatz
Autodesk Support
Autodesk Support
Hi @themetricguy,
Also forgot about some preferences you can toggle!
James Youmatz
eric_strebel
I wish you could shift the shadow like in sketch up, that would be a game changer!
