How to mill gridlines with a V-bit?
sstephan_h
sstephan_h
Hello community,
I have designed gridlines (see photo) which I want to mill into my spoilboard using a 90° V-bit at 0.5 mm depth (maybe 1 mm, but I guess that doesn’t matter much).
My idea was simple:
  • Take the sketch → generate the manufacturing model (this part works fine).
  • Then I selected Engrave, set the depth to -0.5 mm from the surface → also works in principle.
Problem:
When I select all lines, Fusion only generates a toolpath around the outer boundary. The inner horizontal and vertical gridlines are ignored, even though I have them selected.
I can’t find a solution – it seems Fusion just doesn’t want to generate a toolpath for the internal lines.
Any advice how to get Fusion to mill all the gridlines with a V-bit?
Thanks in advance!
Stephan
TheCADWhisperer
@sstephan_h
It probably would have been more appropriate to post your question over here...
Fusion Manufacture Forum - Autodesk Community
Warmingup1953
You can create Patterns in the CAM environment. A simple sketch with just the first X and the first Y paths will suffice, although I would probably suggest 2 U-shaped paths to avoid backtracking
Warmingup1953
This is better with U-Shaped paths:
sstephan_h
I moved to the manufacturing section
Thank you very much! 🙂
