How to make a spline that follows body shape
I am trying to make a spline that follows the outer form of my helmet. Afterwards I will choose Create/Pipe and select the spline as the path. Doing this I will make "vent-holes" in my helmet.
The problem is, that when I make the spline, looking from the Right view, it looks ok. But when I then rotate a bit, I can see the spline is all over the place.
How can I make the spline, so that it follows the outer form of the helmet body ?
Any advice is highly appreciated, thanks :))
Ola
davebYYPCU
For a planar sketch,
Create Section Sketch.
Edit Section Sketch and Create > Fit Curves to section, Select curves or spline.
For a 3d sketch, Project  > Include 3d Geometry, select the curve points you want,
Hide the body and join the dots.
Might help.
g-andresen
here are 2 ways applying curves on a helmet:
1. sketch > split face > create pipe
2.  start sketch on offset plane > create curve via "project /intersect" > create pipe
günther
Thank you so much ! 🙂
