how to link the two joints
I can't figure out how to make it so the lower and upper leg stay together when bending.
jhackney1972
I do not think you are off on the right foot.  You are having to created sub-components inside of forms to try and get a viable joint.  I believe you would be a lot better off to create your components directly and then joints will be a lot easier.  Take a look at the attached example of one motion joint between similar components and see if it is a better idea for you.  I tried to mimic your assembly joint by making the socket slightly larger than the ball but that can be adjusted.
John Hackney, Retired
